How to make crossing the default in the trim command, AutoCAD 2021...
asdemeter
Message 1 of 8
asdemeter
For those of us who have been using AutoCAD for many years, that new default is awful.  And what's worse is that, not only do I have to type C to get what I want, I have to do it every...single...time I trim objects, even within the same command session!  Has anyone figured out a workaround for this?  And why ever would Autodesk not make it a part of the options, so we can choose what our default is?
Replies (7)
Message 2 of 8
imadHabash
if i understand you well ... you can pick your mouse in a certain point and go left for crossing option mode , isn't it ?
Imad Habash
Message 3 of 8
vinodkl
Yes I understand your struggle. It takes some time to get used to new things🙂
If you want trim act the way it used to be in the prior version then type in the command "TRIMEXTENDMODE" and set it to "0". That will fix that.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 4 of 8
asdemeter
Thanks!  That worked!
Message 5 of 8
triarcbim01
Observer
Observer
This is what i am looking for for the whole 2019 - 2023. Thanks a lot
Message 6 of 8
arshadmirza786
Instead "BEXTEND or BTRIM" ,can be used
Message 7 of 8
vincenzo.bondaneseEMTUH
Community Visitor
Community Visitor
Tks a lot 🙂
Message 8 of 8
triarcbim01
Observer
Observer
That works too. But, i used to Autocad 2007. So, i feel like changing the TRIMEXTENDMODE is one time headache. Thanks for the tips.
"Anyway, the user interface since Acad 2005 has been greatly improve. Just need a lot of time to read the update"
