How to make a random geometry on AUTOCAD
I want to make a random sponge like 2D geometry on AUTOCAD for my model and I am having difficulty in doing so.
I have attached a picture that, I want 2D geometry like this, can someone help me?
imadHabash
i think that your attached image has a 3d effect texture , you may need to do it as a 3d model then take a flatshot to this 3d object .
Imad Habash
Thank you for your reply. I agree, but I want that in a 2D. Also, let's say I make the 3D image, how do I make that geometry, do you have any idea?
imadHabash
by FLATSHOT command . >> Click <<
Imad Habash
Kent1Cooper
This looks like something for which AutoCAD is not at all the appropriate software.  I suggest you look for a way to do it more easily in some other program, and from there, put it into some form that you can import into AutoCAD, whether by raster-to-vector conversion, via PDF somehow, or probably other possibilities.
Kent Cooper, AIA
j.palmeL29YX
Something like in the attached dwg?
Jürgen Palme
ChicagoLooper
You can use SUPERHATCH command (go to Express tools Tab=>Draw Panel=>Super Hatch Icon). For the hatch itself, you can select to use an image or a block (or a few other options). You can use an image of a sponge or you can create a sponge pattern using circles, arcs and lines. Once your pattern is drawn you must turn it into a BLOCK. Your block will be the actual hatch that you can scale, rotate and apply to an enclosed area , just like regular hatch. To see how it works, watch this >>VIDEO<<.
Source: Lynn AllenSource: Lynn Allen
Chicagolooper
