How to make a 3d solid from a 2d wireframe i drew
Message 1 of 10
Would love some help off some one more skilled than I.
I am using 3d modelling. I would like to create a shape (which i have drawn in 2d as a wireframe off what i would like as a 3d solid).
unfortuantely i am having great difficulty. i can you extrude, loft or revolve due to the nature of the shape which is basically a wedge with a curve at the top.
Any help would be great!
Thanks in advance.
Replies (9)
Message 2 of 10
imadHabash
depending on the way that you make your model , you may try different ways !!
would you please share with us your CAD drawing for testing ? ( AutoCAD 2013 format type )
Imad Habash
Message 3 of 10
Thank You!
Message 4 of 10
imadHabash
since i have 2017 version , SAVE AS your drawing as AutoCAD 2013 version type please ?  🙂
Imad Habash
Message 5 of 10
sorry, re-done now
Message 6 of 10
parkr4st
in this example the profile was copied and the top corner bought down to the curved line.  More profiles will increase the accuracy to the solid.   first copy was pasted to the center point of the lower front line and other two using m2p.
Message 7 of 10
Thank you!
I really appreciate your help.
But using your model, these are all still polylines, how do i make all of these 1 3D solid?
Message 8 of 10
parkr4st
My bad
LOFT command
Message 9 of 10
YOU ARE A GOD
Message 10 of 10
imadHabash
you can draw full wedge model then copy your arcs to the wedge then by using PRESSPULL command you will get it . see attached drawing .
Imad Habash
