How to lighten a 3D dwg file that is too big ..i need to import in revit
Hi, I need to import in revit a 3d dwg file, the problem is the imported file is too big around 14 MB and slow down revit .. so i'd like to lighten the dwg file that is full of lines.. the file is in the attachments.. maybe to reach a size of a few MB ..
Can someone help me?   thanks
jayhar
Please Upload AutoCAD 2013 format.
Try this. delete unwanted Layers in Drawing & WBLOCk.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
I uploaded the autocad 2013 format , it is in the attachments
jayhar
I download your file, its 22 mb, Now its 13 mb. there is no hidden drawings, no layouts & layers. Maximum clean up WBLOCK, EXPORTTOAUTOCAD, COPY/PAST to New file. This is actual size of drawing, what i understand. please wait i will back. see the attachments
ok thank you i'll wait ..however it was 22 MB because autocad 2013 ... i've autocad 2018  and it's 14 MB ..i'm trying now the commands you wrote
jayhar
Your file is showing every thing is good. file size is 11.8 mb.
BLOCK REFERENCE  Layer: "0"
                            Space: Model space
                   Handle = 167
       Block Name: "60150965_ASM"
                at point, X= -85.7365  Y= -24.6604  Z=   0.0000
   X scale factor:   25.4000
   Y scale factor:   25.4000
   rotation angle:      0
   Z scale factor:   25.4000
         InsUnits: Millimeters
  Unit conversion:    0.0394
  Scale uniformly: No
  Allow exploding: Yes
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
leeminardi
Explode the drawing in AutoCAD and save each subobject as a separate file and then import to Revit.
This picture shows the subcomponents in different colors.
lee.minardi
