How to join offset lines
I have offset a Pline and now I need to join the starting point and endpoint of the source Pline to the corresponding ones on the offset Pline. Is there a simple way to do that?
Thanks.
parkr4st
draw one in,  pedit, join and close
@parkr4st wrote:
draw one in
Draw what in?
Alfred.NESWADBA
I guess @parkr4st meant draw one line (or polyline) between startpoint of source object and startpoint of offset object, then use command _PEDIT and option _JOIN to create from the source-poly + the new line + the offset-poly one joined object and (within the same _PEDIT command) use option _CLOSE to get the endpoints connected.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
parkr4st
thanks Alfred.   Just what I meant.  wasn't very clear on that was I?
Now it's clear; thanks.
