Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been using Draft sight and set up several layers in draft sight which correspond to my print configuration. I want to import this layers into Autocad so that I can use these layers in Autocad too. I have managed to export the layers to a .xml file but I am unable to import these into Autocad. Does anyone have any advice on how i can do this.
I have tried importing the file using the CUI and importing the file as a customisation file. I was able to import the file this way but then cannot access the layers. If anyone has any suggestions that'd be great 😄
Thanks in advance
