How to import more than 20 items in Custom Properties?
Message 1 of 9
Hello Folks,
anyone can help me in order to import more than 20 items in Custom Properties(Drawing Utilities=>Drawing Properties). I tried propulate function but it did not work. I need to do that everytime I start a new drawing.
Sorry I did not find any topic that  seemed to request it.
I am using AutoCad 2018
Thanks in advance.
Replies (8)
Message 2 of 9
RobDraw
Have you considered putting them into your template rather than importing them with every new drawing?
Rob
Message 3 of 9
Hello Rob, I do considered that but the problem is that I work with another 3D software and after creating the 2D in this software I need to export the 2D in DWG and once I copy and paste from the dwg generated into the template(real Auto Cad template), scale  and information get lost.
Message 4 of 9
RobDraw
Your description is hard to fully understand without examples.
Rob
Message 5 of 9
vinodkl
Hi @Anonymous
Are you looking to import the custom properties from another drawing? if yes, then you need to try the lisp attached to steal the custom properties from another drawing. If you are looking for something else, then please upload some screenshots or drawing so that we can help you out 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 6 of 9
Many thanks it will help me for sure.
Message 7 of 9
eric.masonEERCB
@vinodkl,
This worked perfectly. I have about 30 custom fields set up to auto populate in several places over several sheets in my template. The custom fields hold different data with each drawing I do, so importing once into the template is not the answer. I don't have to use this often, but my template gets updated fairly regularly with nice tweaks that make the drawing process smoother each time. After getting used to these updates, working in an older version is a drag so I like to transfer all of the old drawing entities to the new template. This made that task so much easier and quicker. Thank you.
Message 8 of 9
ben_bamba34QTT
Community Visitor
Community Visitor
Accepted Solution. Very good.
Message 9 of 9
TomBeauford
I've used Lee Mac's Steal from Drawing more than any two other lisps I've ever downloaded combined. Couldn't get by without it!
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
