I'm trying to identify the rooms shown in image aboverooms shown in this image. Rooms are formed using line not polyline, I have used DFS algorithm for getting the closed of line but not able get this room from lines, some lines fall in the both the closed loop. Any idea how we can achieve this
Solved by paullimapa. Go to Solution.
What is a DFS algorithm? What do you have (post your file please) and what do you want to get?
Jürgen Palme
Are you familiar with AutoCAD's Boundary command?
AutoCAD 2025 Help | Create Boundaries Efficiently | Autodesk
@paullimapa yes this solution work able to find closed loop with text location.
Glad to have helped…cheers!!!
