How to get the calculator for scale factor in the Scale command
Karol-Or
Karol-Or
Sometimes, i don't remember how i did it, i get the prompt for calculating the scale factor, instead of just having to input the scale factor.
For example it asks for the current value, for example i enter 4, and to which value i want to scale and i enter, for example, 3. then it calculates the scale factor.
It's good because i can select the current endpoints and write the new desired length.
imadHabash
as i understand that during a command you want an access for QuickCalc transparently :
  • Right-click to display the shortcut menu, and choose QuickCalc.
  • At a prompt for a value or coordinates, enter 'quickcalc or 'qc.
Imad Habash
GrantsPirate
At the command line watch for the Reference option, pick that or type R and hit enter.
Scale, select objects, base point, scale factor or (Copy/Reference), ...
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
leeminardi
After specifying the base point you can type
'cal [ENter]
and then type in an equation.
For example, the following sequence will scale an object up by Fibonacci's ratio.
Command: SCALE
Select objects: 1 found
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: 'cal >>>> Expression: (0.5 + 1.25^0.5)
Resuming SCALE command.
Specify scale factor or [Copy/Reference]: 1.6180339887499
lee.minardi
Karol-Or
First of all thanks for the help. the 'qc was helpful, but i wanted something else.
Yes, sometimes i get the prompt for Reference when i use Scale, but sometimes not!
And 'qc doesn't let me choose points, it only enables me to calculate
