you get that dialog every time a drawing searches for an SHX file but does not find it.
If the SHX file is missing AutoCAD can't display the linetypes correct or shows text objects with another/wrong font.
Either you have that missed SHX-file, then place it in one of the AutoCAD support folders (or edit the options in AutoCAD and add a support folder to the folder the SHX file is stored).
If you don't have the SHX file first try to get it (ask the one who created that drawing) ... or change the linetypes which use this SHX to another linetype.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
