How to get rid of Proxy objects in an AutoCAD drawing.
john.vellek
Alumni Alumni
Message 1 of 23
john.vellek
Do you keep getting a popup when you open your drawing that indicates that you have proxy objects in your file?
John Vellek
Replies (22)
Message 21 of 23
jpace
Where I work we have gotten proxies that cannot be deleted with any export to autocad, or any creative method such as xref into a new template and bind. When this happens it is usually from the Network130 or some other smart pipe or pressure pipe proxy, dropped off by a Civil 3d user of a more current year. That said, the solution I found is to either enable your software with all the years leading up to the current year, or finding that Zombie Killer LSP, and use that to run the command in the culprit drawing, and it finds those proxies I mentioned and deletes them all. Works like a charm for me since I found zombie killer nearly 5 years ago or more.
Message 22 of 23
jpace
find Zombie Killer Lisp routine, and then run it in your Autocad session, then it will delete the proxies that are causing you issues, with no need to save down thereafter.
Message 23 of 23
johnhuan
type acad command:  proxyshow,  then change value from 1 to 0.  you can hide the ACAD_PROXY_ENTITY objects.
