How to get rid of Proxy objects in an AutoCAD drawing.
john.vellek
Alumni Alumni
Message 1 of 23
john.vellek
Do you keep getting a popup when you open your drawing that indicates that you have proxy objects in your file?
John Vellek
Replies (22)
Message 2 of 23
john.vellek
You can turn off the notification by setting the system variable PROXYNOTICE to 0.
If you aren't round-tripping your drawing with a vertical such as AutoCAD Civil 3D or AutoCAD Architecture you can certainly get rid of the proxy objects. The easiest way to to do this is to use the -EXPORTtoAUTOCAD command.
This command has several options that you can set before saving the file to a new, plain AutoCAD file:
  • Filename
  • Format
  • Bind
  • Prefis
  • Suffix
This command can be a fast and easy way to resolve proxy issues in your drawing files.
John Vellek
Message 3 of 23
clindner
I never thought of posting a question, then posting the answer, and then marking it solved!  Lol! Not a bad idea, actually.
Please use the Accept as Solution or Kudo buttons when appropriate
Chris Lindner
CAD Technology Consultant @ onebuttoncad.com
AUGI Board of Directors
Message 4 of 23
pendean
Community Legend
Community Legend
John is "Autodesk" and he posts a lot of user tips, these forums only allow solutions to be tagged on replies, not original post.
This is an easier solution than the one posted IMHO if you are not stuck with AutoCADLT https://apps.autodesk.com/ACD/en/Detail/Index?id=1498235021060360128&appLang=en&os=Win32_64
Message 5 of 23
clindner
I know, I'm just "bustin' his chops" a little. 😉
I just never thought of posting a question I already had the answer for, then post the answer, and then mark it as the solution to boot! Nice way to bump your post/solution counts.  Not a problem, just an observation.
Thanks for the Zombie Killer link. Nice tool. Just wish it had a "batch" option.
Chris Lindner
Message 6 of 23
pendean
Community Legend
Community Legend
It sure can be since there is a commandline name for the tool... .
Message 7 of 23
You can use DWGCONVERT as a batch converter, if you have the OLE object enablers installed there should be a "Convert to xxx version with OLE objects exploded" option.
Message 8 of 23
I don't see any reference to that feature in the documentation.
I tried:
-KILLZOMBIES
and
(command "KILLZOMBIES")
but both display a dialog box.
What's the secret?
Message 9 of 23
Interesting. Good idea. I don't see the "Convert" option.
Thanks, though.
Message 10 of 23
Well... apparently it exists (though I don't have it on my version, @cadffm says he has it on his).
Civil 3D has a batch converter if you have access to that software, command in Civil 3D is CIVILBATCHCONVERTER
Message 11 of 23
cadffm
the "convert" option is just the fileformat option.
Are you running the DWGtrueview DWGconvert?
You see the fileformat option?
But not the Autocad dwg **** with exploded AEC Object Option?
Have you installed the C3D ObjectEnabler?
Sebastian
Sebastian
Message 12 of 23
shallowhead
You know, I tried the -exporttoautocad command and the resulting file still has the proxt objects.....
why would that be?
KT
Message 13 of 23
cadffm
The program needs to know what kind of object it is (you need this program, add-on or an object enabler).
If it is a Proxy object, your program doesn't know what it is and how to "convert".
If you need help, we need to know the missing program.
Open the file while proxynotice is ON.
Read the pop up about proxys(scroll down, there are more than one i guess).
And what program is running on your side? Command ABOUT shows the product name and version.
Sebastian
Message 14 of 23
shallowhead
OK, Thanks.
Here's a screenshot of what the proxy objects are:
I'm running Autocad map 3d 2010. My system is windows 7, 64-bit.
I'm thinking that I dont have an obj. enabler for civil 3d, but I can't find one?
Any ideas?
KT
Message 15 of 23
cadffm
1. The creator should use -ExportToAutocad
If not possible(why?)
Install DWG TrueView
also the OE
https://knowledge.autodesk.com/support/autocad/downloads
Start DWG TrueView and use the DWG Convert tool.
Set up the convert settings to DWG 2010 without AEC Objects or ??? (You have to look what the program offers)
I can not run a test for you, so HTH
Sebastian
Message 16 of 23
Hi @shallowhead ,
I believe that each year-version of Civil 3d has slightly different object enablers, so if you can find out which version of Civil 3d was used to create the drawing, (maybe ask the person who sent it to you) that might speed things up as you can then just only install the relevant one.
Here should be all the object enablers so you can look and find which one you need: Autodesk object enablers
If you want to keep the civil 3d objects and their associated meta data, then just install the object enabler and you'l be able to view them (but not do too much else to them). If you want to "explode" them, then use the EXPORTTOAUTOCAD command.
Message 17 of 23
mehrabi.m.k
Community Visitor
Community Visitor
Lol
Message 18 of 23
shallowhead
Thanks Marianne!
Message 19 of 23
ahansonEXZYU
Community Visitor
Community Visitor
What do you mean round tripping?  Because that seems like what I might be trying to do.  I basically setup a template in Plant 3d using project manager sensitive fields and then realized I have civil 3d proxies.  I installed the object enablers and still no joy.  The proxies persist.  I don't want to have to redo all the fields; is there any way to avoid saving down to a autocad dwg?
Message 20 of 23
RobDraw
You should try posting in the Plant 3D forum so other P3D users can possibly give you solutions that can't be done with vanilla AutoCAD.
Rob
