how to generate a .geo file ?
pierre_genevoisENVVZ
Observer Observer
Observer
Observer
Hello, how to generate a .geo file containing 2D geometry ? TY
TheCADnoob
Are you trying to convert a .DWG to a .GEO? Or are you just trying to create a .GEO file?
CADnoob
Valentin_CAD
@pierre_genevoisENVVZ ,
The GEO file type is primarily associated with TurboCAD.
If that is your case, consider asking the TurboCAD Forum.
Otherwise, provide your ABOUT information.
Related:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Observer
Observer
I try
- either to generate directly that simple 2D geometry using a text editor, with extension .geo,
- or to use a software (e.g. Autocad) for both generating that simple geometry and converting it to a .geo file.
Valentin_CAD
Unfortunately, AutoCAD does not work with *.geo file types.
I suggest you look at other options.
Related to AutoCAD:
Emilio Valentin
TheCADnoob
@pierre_genevoisENVVZ wrote:
I try
What are you trying to accomplish by using a .geo file? Is there another file type that might be more suitable for 2D work that you can use? .geo seems to be made for 3D use.
CADnoob
