how to find length of entity from dxf file ?
Can i find length of entity from dxf file ?
if not will i get the length of entity(spline or polyline) by analysing entity data from dxf file ?
Alfred.NESWADBA
Within the DXF you find data how objects are created, not the properties from calculations.
You'll have to do your calculations by yourself of by loading the DXF-file into a software that knows the object an can do the calculations for you.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Thanks for the answer.
i am creating a software to calculate length of object from dxf file.
i am referencing dxf file format for this operation.please provide any hint
to calculate the length of object from dxf file
Alfred.NESWADBA
>> please provide any hint to calculate the length of object
Which object type(s)?, this can be a simple line, curved or splined (2d)polyline, 3d-spline, up to application specific proxy objects ...
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
sorry, please don't wait for results from my side ... I would have to use Google-search for geometry calculation sites too.
And I would estimate differences in when calculating splines as there are some different calculation methods depening on the parametrization.
Good luck, - alfred -
Alfred NESWADBA
