AutoCAD Forum
How to find and replace special characters in layer
3 REPLIES 3
jocke.o92
841 Views, 3 Replies
I work with a foreign language, which use letters like Ö,Ä,Å. I get some drawings containing this letters and this creates some problem when doing machine control and using dxf. Those characters' kind of breaks the dxf in the machine.
Is there an easy way to take those letters in the layer and change them to O,A,A? Maybe a lisp that could be modified.
3 REPLIES 3
pendean
in reply to: jocke.o92
>>>...Those characters' kind of breaks the dxf ...<<<
LISP will not overcome DXF issues with those special characters.
Valentin-WSP
@jocke.o92 ,
Try reading these links:
Might also want to look into installing the Swedish Font (if available) - these links may provide some help:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
vladimir_michl
You can use regular expressions in the RRENAME LISP utility (free). Just set the Layers option, search for:
[^\x20-\x7F]
and replace it e.g. with:
_
You may need to repeat this several times.
See https://www.cadforum.cz/en/rename-on-steroids-complex-renaming-of-autocad-objects-tip9265
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
AutoCAD Inside the Factory
