How to extrude shapes on a face
Hollis.williams
Message 1 of 9
Hollis.williams
I have a rectangular block and have then drawn a semi-circle on one side.  I am trying to extrude this semi-circle to cut a semi-circular hole through the block but when I try to select the semi-circle it keeps selecting the entire face.
I have attached the .dwg file which should be helpful (apologies if it is inelegant as I am new to this software).  Hopefully it's clear in the file that I punched circle holes which go through a curved block, and then I am trying to cut a hole through this time given by the semi-circle.  The semi-circle was made by drawing and joining two separate curves on the face which might be part of the problem.
Replies (8)
Message 2 of 9
Alfred.NESWADBA
If you really referring to an AutoCAD block then you can't use boolean operations between one object with a block.
A semi circle is not a closed object. So extruding the object does not result in a volume (3D-Solid) and so can not create a hole in another 3D-Solid.
>> Does anyone know a simple way around this?
With just seeing the screenshot and so not knowing what you really have ... no. Upload the dwg-file and we can (most probably) return with valid suggestions.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
Hollis.williams
I have added the .dwg file as requested, let me know if anything is unclear or if my intentions are not clear.
Message 4 of 9
Alfred.NESWADBA
sorry, this is what I see:
So I have no idea which objects you really mean, 120 object and I expected we get a dwg-file 2 objects, on block (or one 3D-Solid) and one object representing the semi circle.
- alfred -
Alfred NESWADBA
Message 5 of 9
Alfred.NESWADBA
ok, you might are referring to this location? Then command _PRESSPULL could be the function you are looking for ... as shown in the video:
- alfred -
Alfred NESWADBA
Message 6 of 9
Kent1Cooper
Just as a matter of physical possibility, don't you....
Kent Cooper, AIA
Message 7 of 9
Hollis.williams
That is exactly what I am trying to do, but when I use PRESSPULL it just selects the face on which the semicircle is drawn, I cannot seem to select objects on the face.
Message 8 of 9
Alfred.NESWADBA
When you start with a view similar to my one (so you can see the semi circle and your other 3D-Solid behind, then you start command _PRESSPULL and move your cursor inside the semi circle (inside, not the border) ... just cursor move, no click, does it highlight your semi circle?
- alfred -
Alfred NESWADBA
Message 9 of 9
Hollis.williams
No, although I was able to brute force it by moving the semi-circle away from the face and then press pulling it all the way through.
