How to edit this solid?
Message 1 of 21
I have this cube that needs to taper into the round solid at the left. I would like to subtract the 4 slivers in the corners using that plane I revolved to slice through thanks
Replies (20)
Message 2 of 21
Patchy
Use SLICE command
Message 3 of 21
Plane wasn't the right word to use, sorry. It is not flat, I didn't think slice work on this?
Message 4 of 21
Patchy
Let's see your .dwg, it looks simple to do (maybe)
Message 5 of 21
Here is the dwg
Message 6 of 21
Patchy
Like this?
Message 7 of 21
Thats it! Now how did you do that, lol
Message 8 of 21
Patchy
Slice command, click on the cube, then watch the prompt, it will ask for SURFACE, use surface to slice the cube.
Message 9 of 21
Got it to work here on my end, thanks again
Message 10 of 21
I have another solid that I can't seem to slice. I keep getting 'the slicing plane is not intersecting' error.
Message 11 of 21
Patchy
Where do you want it to slice? into 2 equal parts?
Message 12 of 21
Yes please using that dashed line as the plane
Message 13 of 21
Patchy
Like this?
Message 14 of 21
Perfect, whats the trick to getting that to work?
Message 15 of 21
Patchy
Copy the dash line to a different Z , Loft them, Slice using surface.
Message 16 of 21
Awesome, that works!
Message 17 of 21
The reason I wanted to slice this pc is because autocad adds a weird spiky artifact to one side when I STLOUT. I wanted to slice the pc in half, delete the side with the spike, mirror over the good side, and union. When I do that with the above file dwg, I get an 'inconsistent graph vertices' error, any ideas how to get around that?
Message 18 of 21
Patchy
Which side is bad when STLOUT?  if the part is mirrored, the peg hole will not match what you have now.
Message 19 of 21
The left side is the bad side.
Message 20 of 21
Just wondering if you have had a chance to look at this, I can't get these guys to union no matter what I try, thanks.
