How to draw a circle on two lines intersecting point ???
hello,
i need to draw a circle which has center at two lines intersecting point, once we move the cursor to intersecting it will specify the intersecting with different cursor but i don't have a option like that.
please help me on this issue
thank you!
Vinayv4v
Go to you osnap settings and turn on Intersection. (command : OSNAP)
Cheers,
Vinay Vijayakumaran
imadHabash
HI,
OSNAP modes is the the way for that by pre-select it by OSNAP command.or you can type ( int ) in the command line when you asked to specify a point.and don't forget to use F3 for toggling on and off osnap modes.
Imad Habash
