how to do flat surface development for laser cutting
How to do the development of hexagon-shaped base and top, but circular dome in the middle. Kindly check the attachment showing desired shape.
parkr4st
do you want the shape of 6 flat, identical pieces to shape for the curved sides?
parkr4st
Basic drawing.  two hexagons as proper elevations,  the red line is the curve.   SWEEP the red line on the bottom or to hex as the path
Thanks for reply, I want to flatten(unroll) the curve surface( surface development of this figure), so I can cut the same the sheet on laser cutter.
yeah!, I want to know the flattening process of the same.
schulz8NPAP
Here we go.
Good luck
Jochen
www.black-cad.de
Tomislav.Golubovic
Have a look at Fusion 360, you can model it in 3D and then have the software unfold it for you and then you can export the DXF
