How to display the Hatch Panel
CliffTurnerFuse
Message 1 of 11
CliffTurnerFuse
I have been on REVIT too long.
I am on AutoCAD and need to have the Hatch panel displayed when I click on the Hatch icon in the toolbars.
Currently, when I click on a Hatch Icon, I get instructions on the Command Line.
I need to see the patterns available in order to pick a hatch pattern.
Where do I go to turn it on ?
Replies (10)
Message 2 of 11
Kent1Cooper
Does the ribbon not change to the "Hatch creation" edition, including this "Pattern" section that you can scroll in, or pull down to see more at once?
Kent Cooper, AIA
Message 3 of 11
pendean
Community Legend
Community Legend
You will need to edit the hatch button macro in CUI command to do that for you, if typing T the <enter> is difficult to do: which button do you click on exactly? We can't see your screen.
Message 4 of 11
Kent1Cooper
@pendean wrote:
... typing T the[n] <enter> ....
If at the command line you do that, for the seTtings option, then pick on that, you get the palette of pattern swatches:
They're just like the ones in the ribbon's Pattern pull-down, though for some reason not in the same order.
Kent Cooper, AIA
Message 5 of 11
pendean
Community Legend
Community Legend
@Kent1Cooper OP mentioned "toolbar", I'm thinking "classic workspace" aka no Ribbon, so until the OP responds my guess is they are not interested in much of anything else that is not "classic".
Message 6 of 11
CliffTurnerFuse
That solved my problem on how to get the Hatch Patternss.
But, I still have to click on a Hatch Icon, then, on the Command Line, I type "t" to bring up the Hatch Gradient displays.
How do I get it so that clicking on a Hatch button, brings up the Hatch Gradient display ?
Message 7 of 11
peterm
Isn't there a variable to turn dialogue boxes on?
When I click on the Hatch button, I get this (see below) and then click on Swatch or Pattern to see the different hatches.
Message 8 of 11
user181
If you set the variable HPDLGMODE to 1 then you will get that dialog box when starting the hatch command
Message 9 of 11
CliffTurnerFuse
Kent1Cooper had the answer and has earned my eternal Thanks !!!
-Cliff
Message 10 of 11
fkellogg
You might want to try searching the Knowledge Network for
"How to disable contextual ribbon tabs in AutoCAD 2015 and later"
I did not read the whole thing, but you might find what you are looking for in there.
Looks like you used to be able to allow / disallow contextual tabs . . .
Cheers
Message 11 of 11
peterm
That's the one I was thinking of.
I couldn't remember the exact name.
