Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to determine the volume of a solid
hi, im really new here and would like to know how to determine the volume of the solid that i just created. First i already tried the MASSPROP command however i am having a difficulty in determining the volume. It gives me this but the thing is, what is 1.5648E+12?1.png1.png
imadHabash
>>  what is 1.5648E+12? <<
this is the Scientific type of units. you can change it from  -UNITS  command to another type.
Imad Habash
oh i see, so if i am using a 1:1000 scale i should chose the mm right? (sorry im really new in using autocad)
BeKirra
Apart from what Imad has suggested, you should clarify your model scale because technically speaking, models should be drawn 1:1 scale all time in model space.
This will give you a real volume when you measure the model.
You then set desired scale on layout with viewports for your drawing.
FYI Place drawing title block and drawing boarder on layouts.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
i see so that's why i cant get the right answer. Thank you for the help i appreciate it so much Smiley Happy
BeKirra
You are welcome!
X² + Y² = C²
JDMather
@Anonymous
I see this is marked solved, but there are many incorrect or misleading statements in this thread.
Scientific (exponential) notation is not a system of units.
It is a method of writing numbers (especially very large or very small numbers).
If you are not familiar with Scientific Notation, I recommend that you shut down AutoCAD for a bit of time and do some research on this as it is probably a pretty important concept in any design field. Even if you never use very large or very small numbers in your work - you should at least instantly recognize when a value is given in exponential notation.  To not recognize this can lead to significant errors.
The command -units does not change the document units (except for option 3 or 4) as noted on the command line.
Use the -dwgunits command to set appropriate document units.
