>> How do i set the sectionplane not to cut the solids?
>> I just want to project the sectionplane
I don't understand your needs, if you want to create a section you need the sectionplane at the level of the section.
If you don't need a section you don't need a sectionplane.
A sectionplane can't be projected (at least I don't know what the result of a projected sectionplane should be).
Oh, moment ... do you want to create a section block but not display the original object like it was sliced by the sectionplane?
In that case
- select the sectionplane, open the property window and turn off "Live Section"
- use command _SECTIONPLANETOBLOCK ... is that what you are looking for (>>>details<<<).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
