I want to create arranged cylinders on sphere but I couldn't find any available command in AutoCad. And also, If possible, hexagonal close-packing is better. Anybody have some idea about it?
Solved by john.vellek. Go to Solution.
Good morning kuwae,
Welcome to the Forums!
Have you played with the ARRAY command? I think that might get you started. Here is a link to the AKN Article that describes the command.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Hi kuwae,
I haven't seen an update on your post so I thought I would check back. I hope you have looked at the ARRAY and 3D polar array options. I also found this post out on the web that might help as well.
Please post your results so other community users can benefit.
