How to create an uneven, 3D brick in AutoCAD
Message 1 of 14
Hello everyone,
I'm trying to create a simple model of a pizza oven and the first thing I'm trying to do is to simply create 1 brick shaped object that I can move like a box.
The brick isn't even , its 230 in height, 115 width and then 64 depth on one side and 55 on the other, see image bellow brick.jpg
autocad architecture 2021
thank you
@Anonymous
Topic Title has been changed by @Tiana_Y for better findability. Original: Trying to create an uneven box?
Replies (13)
Message 2 of 14
imadHabash
draw the elevation of your model shape then you can EXTRUDE or PRESSPULL it ( 230) .
Imad Habash
Message 3 of 14
Thank you, I should have mentioned i'm a complete novice and I have no idea how you did that shape.
I tried with the lines but how one I do the 64 depth part and I need do the the 230 line, it needs to be in an angle for the 55 on the other side and I have no idea how to calculate that or if that even the correct thing to do
Message 4 of 14
imadHabash
draw a rectangle 115,65 then take from one side both corners a 4.5 to become 55 . now Extrude your shape 230 .
Imad Habash
Message 5 of 14
vinodkl
Here is screencast of you can achieve that🙂
I suggest you  to learn the basics of AutoCAD which you can find on youtube.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 6 of 14
thank you both.
I managed to create that shape, but why isn't it acting as a box? it's still a wireframe and when I change the view to realistic it disappears
, what did I miss?
Message 7 of 14
j.palmeL29YX
@Anonymous wrote:
, what did I miss?
Post your file ...
Jürgen Palme
Message 8 of 14
imadHabash
i think that you should have a polyline 2d shape . if NOT you can try PRESSPULL command then pick inside your shape .
Imad Habash
Message 9 of 14
Kent1Cooper
@Anonymous wrote:
.... I managed to create that shape, but why isn't it acting as a box? it's still a wireframe and when I change the view to realistic it disappears ….
I would guess that you did one of these:
1)  Drew the shape as four Lines;
2)  Drew it as a Polyline, but took the end back to the beginning so that the Polyline is not "closed" under AutoCAD's meaning of the word.
Draw the shape as a Polyline, but for the closing segment, use the  Close option, rather than picking again at the start point.  Then Extrude it.
Kent Cooper, AIA
Message 10 of 14
I think I got one to work , It's not working exactly as a box but I think I can manage with it. thanks.
file attached
Message 11 of 14
j.palmeL29YX
@Anonymous wrote:
file attached
You mix AEC objects (from Autodesk Architecture) with core AutoCAD objects (Solids). That's not a good idea and you will run into a lot of problems (as long as you don't really know what you're doing).
Jürgen Palme
Message 12 of 14
I don't exactly know what I'm doing, but I think if I'm converting it to Mass Element if works better, hopefully that would be fine, I don't need to do a lot.
Message 13 of 14
Can someone tell me why when I select a bunch of 3d solids and convert them to mass element they also unite together? is that something I can undo? I tried ungrouping they they don't seem to be in a group
Message 14 of 14
j.palmeL29YX
@Anonymous wrote:
Can someone tell me ...
If you are working with Autodesk Architecture you should ask in the >>appropriate forum<<.
Jürgen Palme
