How to create a viewport with a breakline?
Title says it all, and I included a splendid paint file of what I try to achieve.Naamloos.pngIs this possible? And if so, how to do this? The paint masterpiece is how I want the plotted outcome to look.
imadHabash
draw a polyline represent the viewport shapes (Bpoly command) then use MV (MVIEW) command with Object option.
Command: MV MVIEW
Specify corner of viewport or [ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/LAyer/2/3/4] <Fit>:
Imad Habash
oswaldodcb
Hello @Anonymous
I made a Screencast to explain how to create the Viewport, in addition to applying the command MVIEW that told you @imadHabash, i use the MVSETUP command to align it, you can also use the SKETCH command to generate an irregular line easily and simulate the one you have in the example,
I hope it will be useful,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
