How to create a viewport in model space
Message 1 of 9
How to create a viewport in MS like this ?How to create a viewport in MS like this ?
I don't know how to create a viewport in Model Space as in attached photo.
I'm using AutoCAD 2012.
Please help me.
Thanks.
Replies (8)
Message 2 of 9
cadffm
"This is not ok"
But i will answer the question.
You can paste viewports, there is not command which create viewports from scratch in modelspace and it is useless in ms,
but it is a perfect troublemaker.
Note: "like this" we can not know without your dwg to check what you have in detail.
For example: An Inventor created Viewport 😉
Sebastian
Message 3 of 9
cadffm
I guess, if you move the viewport, the floor plan moves also?
Then i am sure we talk about Inventor as source of this data.
(Not normal Autocad object/feature)
Sebastian
Message 4 of 9
Thank you. "like this" i mean : gripped object (in that photo), which its property is "Viewport".
I want to create a (rectangle) viewport in MSpace, but I don't know how to do.
I need some helps.
Message 5 of 9
cadffm
As i wrote:
Not possible
  or what possible is, is useless.
Please read them again.
And if you upload your dwg, we can say 100% what it is.
"Like this":
All we see is a stupid picture, nothing more.
Copy&Paste a viewport from Paperspace to the modelspace, now you created a viewport in modelspace.. but why? - useless.
Sebastian
Message 6 of 9
Yes, you can create a model space viewport.       |This guide is from Autodesk support itself|
  1. Click View tab / Viewports panel / Viewport Configurations drop-down arrow.
  2. Click the viewport configuration that you want to use.
The MS viewport is quite useful sometimes especially when you are working with multiple plans in a single MS. This will minimize the error if you are working with massive plans.
Message 7 of 9
Thanks for your help.
Message 8 of 9
ВeekeeCZ
There are two different things called "Viewport" in AutoCAD:
1) Model Space Viewport - HERE FOR DETAILS
2) Layout Viewport - HERE
If I understood correctly, this thread was about if the Layout kind of viewport is possible to make in MS.
Message 9 of 9
Many thanks. I will learn more about these references.
