How to create a fillet between two cone surface parallel to each other
I want to create a Fillet, i want to combine two cone parallel to each other. Actually i want 1.0mm cone wall thickness. So i created a Cone and used offset command with 1.0mm. but walls are not closed.
Please do needful. I want to make a cone of specific wall thickness..
JDMather
@Anonymous wrote:
...So i created a Cone and used offset command with 1.0mm. but walls are not closed...
Is there a reason you are using Offset rather than Thicken?
Is there a reason you are using Surface modeling rather than Solid modeling and Shell?
Can you attach *.dwg file rather than image file?
Please find attached file.
Actually i am new user to auto cad. So i am not expert to choose whether i should select fillet or thicken ?
Can you please guide me when should i use fillet and when i should use thicken ?
Thanks...
JDMather
You need to use Thicken AND use Fillet.
But I am not sure that is what you really really really want.
A solid Revolve and Shell and Fillet might be what you really want.
Or maybe just a Revolve with the fillet in the profile.
Do  you have a picture or url to something similar?
What are you designing?
I want to create a cone shaped Loud Assembly for my Buzzer Please find attached image.
parkr4st
open the attached dwg.  follow left to right.  use 3dorbit to move around.
close to what you need?
Dave
Ohhh thats awesome.. what i need... thanks mate... for idea... appreciate your efforts...
