How to create a custom hatch with an ARC or circle?
mdallinga
mdallinga
Hello guys,
need some advice on creating a custom hatch pattern consisting on an ARC/circle. Now I know one way of making custom hatch through making a notepad file and saving as .pat file and then importing in Autocad. But all the examples I saw online show pattern for only lines and not ARC/circles. I understand that a hatch pattern can contain only straight segments. But there must be a way to do it. I'm aware of the command SUPERHATCH, but that's not the one i'm looking for.
I have attached an image below of the ARC and what I want the hatch to be like. On the right I have drawn the ARC only using polylines, so that should work in a notepad file (in the attachment the .dwg). I just don't know how to write the code when I use so many polylines.
I hope someone can/will help me.
Cheers,
Maarten
Alfred.NESWADBA
>> straight segments.
Sorry, you have found your answer, a hatch pattern can only contain lines and not arcs.
The best you can do is to convert your arc into a number of segmented lines and use it this way.
You might take a look to some free stuff like >>>this<<< (and I'm sure you'll find more samples).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
While you wait... Explore this attached for how arcs are created with short straight segments.
HTH
Kent1Cooper
It's done as you surmise, as in portions of the middle and right pattern images >here<, or >this one<. If those are too kinky for you, it can be done with more segments, to look closer to real curvature, such as in the right side of >this<., or my CirclesTriGrid patterns >here<, which do this kind of thing:
Those are actually 24-sided polygons.  It's certainly possible to take elements of how they are defined and make a pattern like your image.
EDIT:
Here's what your pattern would look like if made with portions of what would be 24-gons if they were complete "circles":
Is that "curvy" enough for you?  It's only 9 segments per "arc," as compared to 21 in your drawing file.
Kent Cooper, AIA
hugha
Try the pattern contained in the attached file.
the pattern was created directly from a WBLOCK'd  DXF of the seminal arc, arranged on a skewed mesh..
hth,
Hugh Adamson
www.hatchkit.com.au
