How to Create a Custom Dropdown Menu in AutoCAD Like AutoCAD’s Layer Selection?
jan_buchholzCJ5DJ
jan_buchholzCJ5DJ
I'm looking to create a custom dropdown menu similar to the Layer dropdown in AutoCAD—where the dropdown displays a name and includes several interactive buttons to the left. I’d like to integrate this directly into a custom ribbon, rather than creating a separate palette.
Is there a way to replicate the behavior and appearance of the Layer dropdown menu within a ribbon (.cuix, etc.), or would I need to use WinForms to achieve this?
paullimapa
Drop down lists with certain functions can be customized in a dialog box and then populated using lisp. But not sure if this can be replicated inside the ribbon
Paul Li
IT Specialist
@The Office
Simon_Weel
Those are special elements - not something you can create yourself?
pendean
Community Legend
Community Legend
@jan_buchholzCJ5DJ That's not open to end users. Sorry.
But there are other limited-ability "pulldown" menus and toolbar buttons if you only want to access built-in tools in CUI command.
jan_buchholzCJ5DJ
Thanks for the clarification! I was hoping there was a hidden option in CUI to create something more integrated, so that’s a bit disappointing. Opening a new palette or dialog box just to achieve the planned dropdown functionality feels like overkill, but good to know the limitations. Thanks again!
cadffm
similar is a FLYOUT (for a static list of entries)
(Your Screenshot is cutted tight, is from QAT? TOOLBAR? or part of an Panel in tab of the ribbon?)
Sebastian
jan_buchholzCJ5DJ
Thanks for the reply. The layer dropdown in my screenshot is in both the QAT and the Layer tab of the Start Ribbon. Since I need dynamic functionality (non-fixed number of elements, interactive buttons), a flyout won’t work, unfortunately.
