How to create a custom command?
Hi everyone!
I always make a mistake of toggling around my plans by clicking the wheel and pressing the shift key.
so everytime i make such mistake i have to change my view to top view.
wanting to save time, i would like to create a command like below;
input:   "TT"
output:     -view    ->   orthographic    ->    top
ive been searching online how to make this happen
but its been a month only for me to use autocad
please help me and save my future architecture assignments 😉
Alfred.NESWADBA
isn't it easier to use the viewcube or the viewport controls?
No need to define anything, works well with AutoCAD OOTB
If you need the command, then:
(defun C:TT()(command "_-VIEW" "_ORTHOGRAPHIC" "_TOP"))
This defines the command as LISP statement, ready to be called then with
TT<ENTER>
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
your suggestion is good as well but switching from keyboard to mouse takes longer time to save time
i followed your instruction and worked really well
but how do i add such custom sequence to aliasedit thing??? that i can use such sequence everytime i use autocad???
Alfred.NESWADBA
Add this line into the existing ACADDOC.LSP, if you don't have such a file, then create a new one (>>>details<<<).
- alfred -
Alfred NESWADBA
illusionistNUGXG
You can create a keyboard shortcut for that with the customer user interface.
How to do:
(sorry, the pictures are made with the german version of AutoCAD Mechanical 2019)
  1. open the CUI
  2. create a new command (pictute CUI-1.png)
  3. fill in “top view” as name - or whatever you like (picture CUI-2.png)
  4. copy & paste the macro into the macro-field
  5. open “keyboard commands” (i guess it should be named something like that)
  6. drag and drop the new command into “keyboard shortcuts” (picture CUI-3.png)
  7. the command is now in that list - click on it, and assign a shortcut - shift+T or F12 for example*. Don’t write it in - use the [...]-button! (picture CUI-04 - oh, limit is 3 pictures...next post)
  8. apply - of course
Now you can change to the top view with your keyboard.
* i never changed any aliases for commands, so i can't give further instructions to assign it as "TT"-command.
The macro is:
^C^C_-view;_orthographic;_top
illusionistNUGXG
picture 4:
