How to correct a Fatal Error: Unhandled Access Violation when saving a drawing
How to correct a Fatal Error: Unhandled Access Violation Reading 0x0000 Exceptio at dff898e4h when saving a file. This happened in AutoCAD 2012 when trying to save a drawing.
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Just one drawing? Then open that drawing with command _RECOVER and let errors in the database be repaired.
If that happens with every drawing (e.g. creating a new drawing based on an original template, draw a line and run _SAVEAS) then
you might have set a default save format to an old dwg file version
you might have an application or plugin installed raising that issues
your AutoCAD profile is defect (you can try your AutoCAD with another Windows user account)
you have an antivirus software or drivers (like saving to dropbox or something like that) which blocks some traffic.
Just a few ideas to try, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I ended up sending the error onto Autodesk and it sent back a link with a fix for the error I was getting. Once I applied the fix the issue was corrected.
Thanks for your assistance,
Vince
Alfred.NESWADBA
for future readers with the same or a similar issue what link did you get that fixed your issue?
- alfred -
Alfred NESWADBA
Could you please provide the link?
Having the same issue and haven't received link from error reporting.
Thank you,
Todd
