How to copy a view port generated by base view to another file
seeldoradoiron
seeldoradoiron
Hello every one,
I am desperately in need of the following:
    I have been trying to copy a projected, detailed or section view generated by base view with all the dimensions and notes from one  layout  to another one in same file or different one and have not had any success.
Is this  actually an option or a future in AutoCad 2022?
I need this option to  generate details from all the parts in a drawing  into another sheet which can cover most of the details.
Thank you
devitg
@seeldoradoiron  di you try wblock ?
Valentin_CAD
@seeldoradoiron ,
Refer to the following link as a workaround:
https://forums.autodesk.com/t5/autocad-forum/copy-drawing-views-between-layouts/td-p/8497695#
Use Product feedback to tell Autodesk what you think about its products and any improvements you'd like to see.
You can also complete your suggestion on the Autodesk User Group International (AUGI) wish list - LINK.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
