How to convert X and Y axis to long lat by using formula
How to convert X and Y axis to long Lat by using formula or  field Attribute?
TerryDotson
If your drawing is in UTM coordinates there are formulas to obtain lat/long values.  However almost all of the time the coordinates must be projected to the lat/long system.  Remember that lat/long is spherical and all drawing coordinates are planar, so even if you used coordinates of -180 to 180 your geometry will be distorted in the drawing.
Beware the AutoCAD Geolocation command that lets you pick a point and enter lat/long, etc.  True mapping does not work that way and you could find yourself doing a lot of work that you later discover is worthless.
Your best solution is to enlist the help of a surveyor or geodesist to help get you started on the right track.
