How to convert .dwg files in Autocad to .gbr (Gerber)
Dear all,
I have prepared design for a mask in Autocad which I need to convert to .gbr (Gerber). Can anyone please suggest a free software for the same? Thank you in advance.
J.FOCHT
Hello @Anonymous,
Check out this forum discussion. It may help you out.
https://forums.autodesk.com/t5/autocad-forum/dwg-to-gerber-gerber-to-dwg-converter/td-p/6628832
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
