AutoCAD Forum
How to Convert Aligned Dimension to Rotated/Linear Dimension Globally..
10 REPLIES 10
Message 1 of 11
10693 Views, 10 Replies
Dear Friends & Masters,
Need Help again for this query,
one of my man by mistake gave aligned dimension instead of Linear,
now it will be a big task for us to delete all the Dim and do it again,
So can anyone help, i need to
Convert those Aligned Dimensions to Rotated/Linear Dimension Globally,
so please if you all have any suggestions or solutions for this please reply.
Hoping a reply
Spoiler
10 REPLIES 10
Message 2 of 11
3wood
I reckon you need a lisp routine to do the work.
Message 3 of 11
mmelechinsky
You'll find two possible solutions listed in a reply to your thread over at CADTutor.
Message 4 of 11
in reply to: 3wood
Thanks for the Quick response,
Is it possible to get that lisp file
Message 5 of 11
in reply to: mmelechinsky
Thanks for valuable suggestion,
But i did not find any of them working
i tried changedimobjects.lsp but it dosent change any of the stuff
Message 6 of 11
mmelechinsky
You must have done something wrong. Try again.
Message 7 of 11
No sir,
i did the bellow
Command: CHANGEDIMOBJECT
Select objects: 1 found
Select objects: ; error: no function definition: DTR
Specify point on positive-Y portion of the UCS XY plane <129.4576,138.5712,0.0000>:
then i checked the properties its still Aligned Dimension 😞
Message 8 of 11
Kent1Cooper
DTR is a common name for a Degrees-To-Radians converter, which they must have omitted from their command definition, probably because they have one loaded automatically.  Try putting this in:
(defun dtr (deg) (* (/ deg 180.0) pi))
You should be able to just paste that into the Command: line and try the CHANGEDIMOBJECT command again, but ideally you should include it in its .lsp file [if that's what it is], or in acaddoc.lsp to load it automatically.
Kent Cooper, AIA
Message 9 of 11
in reply to: Kent1Cooper
Yessssss ...It worked...
Wow That was Awesome ......wow wow...
Thanks a lot...to all of you
and special thanks to Kent1cooper
 you all are awesome
Message 10 of 11
Nasim.Jenabi
thank you for your help, but another question if we want to keep the angle as it is what we can do ?
Message 11 of 11
cad.student
Dear I want that Lisp file and how to use it
AutoCAD Inside the Factory
