How to convert a microstation font from a dgnlib to an autocad font
dvalentiW5B93
Message 1 of 20
dvalentiW5B93
Since our office is primarily Autocad all of our work is done in civil 3D.  Our client needs Microstation deliverables so our DWG files are ultimately converted to DGN for submission once our survey is complete.  I do use a microstation config file provided by the client so we are able to convert our DWG files using the clients standard layer names, colors, linetypes, etc. so all of the linework is meeting their standards requirements. Recently it has been requested that we use their fonts (these appear to be Bentley fonts when I look at them in the DGN file - that being the dgnlib file the client sent along with their standards) .
The fonts I need to use in our Autocad DWG are part of a dgnlib filetype. I am trying to figure out a way to pull out 3 or 4 specific bentley fonts so I can copy this font and use in our autocad file when adding text so I do not have to edit every piece of text once I convert our DWG to a DGN to send to the client.
Any help would be greatly appreciated !  This has been giving me a headache all morning with no resolve 😞
Replies (19)
Message 2 of 20
Patchy
If your client accept the windows fonts, then use them
Arial font tested here:
Microstation vs Autocad
Message 3 of 20
paullimapa
try the recommendations on this link:
http://www.mdlapps.com/microstation/ustnhelp1065.html
Paul Li
IT Specialist
@The Office
Message 4 of 20
dvalentiW5B93
Thank you for your suggestion. I can use the Arial font for some of the text and lables, however the client was very specific about particular fonts to be used for certain types of callouts.
There are 3 fonts in particular they are requiring  (font061, font 062 and font063)
I can see the fonts are available in the microstation file (see screenshot)
but there are no individual font files that I can copy into my Autodesk Fonts folder to use in Autocad.
The microstation fonts reside in a microstation .dgnlib file !
Message 5 of 20
pendean
Community Legend
Community Legend
Here is what Bentley recommends you do:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v19/en/GUID-716D3B47-21FF-6061-D05E-97C...
and
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v19/en/GUID-0296C8EC-46F9-4855-C21B-A14...
You'll probably need to seek out further assistance in the MS User Forums, here is the link (you have to sign up to see any content, their rules, but it's free):
https://bentleysystems.service-now.com/community
Message 6 of 20
Patchy
You can export MS fonts and use with Autocad if you have Bentley.
Open the MS drawing with Bentley, Save as,
Use the option and path it where Autocad can find them.
Message 7 of 20
dvalentiW5B93
Thanks for your reply !
I followed the link for instructions and used the "OPTIONS" to convert the fonts to a shx file while converting the DGN to DWG.
The fonts did export to shx files so and I added a temp folder in my autocad support so Autocad would find the fonts.
Now - my only dilemma - the fonts show up as "hollow" text in Autocad which is not how the same font appears in Microstation ....
I hope I'm half way there to a solution .
Thank you for the suggestion
Message 8 of 20
dvalentiW5B93
thank you -  I tried the saving DGN to DWG and used the option to save the fonts as shx.....
now I have the fonts in shx format - but they do not appear correctly in Autocad - the shx exported font format is hollow text , but the same font in Microstation is not hollow text.
I think I am one step closer to reslove  - thank you
Message 9 of 20
dvalentiW5B93
Thank you and to everyone else who has been replying to help me solve this problem.
I did get to that step  - now I need to figure out why the "exported" microstation fonts are appearing as hollow text when I use it in Autocad. It was not hollow text in Microstation.
Message 10 of 20
paullimapa
Glad that kind of helped...but it looks like the conversion is not perfect which typically can happen dealing with solid filled typeface. I wonder when after you've converted the DWG to DGN and you open them in Microstation is that an option for those now same matching name fonts to automatically read the actual font definitions in the dgnlib filetype?
Paul Li
IT Specialist
@The Office
Message 11 of 20
Patchy
There are fonts that are not transferable, also linetypes, hatches.........
These two companies aren't partners and it has been that way for a long, long time.
Message 12 of 20
pendean
Community Legend
Community Legend
@dvalentiW5B93 wrote:
... fonts are appearing as hollow text when I use it in Autocad. It was not hollow text in Microstation.
Message 13 of 20
Valentin_CAD
@dvalentiW5B93 ,
... I need to figure out why the "exported" microstation fonts are appearing as hollow text when I use it in Autocad. It was not hollow text in Microstation.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 14 of 20
dvalentiW5B93
I just opened the Autocad file in microstation,  after using the converted font that shows up "hollow" in Autocad and unfortunately when I save back to microstation the font changes to simplex instead of the original microstation font it was supposed to be.
I'm going to have to contact our client - there doesn't seem to be a viable way to do this.
BUT I a opened to any other possible solutions - if there is one !!
Thank you to everyone for posting to try and resolve, it is greatly appreciated.
Message 15 of 20
Patchy
There isn't any other possible solutions, I work with both for 20 years and it is what it is.
Message 16 of 20
dvalentiW5B93
thank you. I'm not really sure how to do what your suggesting. If I were to remap fonts would it still go back to the original microstation font when I go back from the Autocad file to microstation ?
My original goal was to get the microstation fonts our client wants into an Autocad template. Then our survey work would be done in Autocad.  I need the fonts to appear properly in Autocad because we produce a signed and sealed survey map for submittal.  Once our survey is complete, our client wants a DGN file of the existing survey (with Their fonts used for labels) and they proceed with the design work for the project inhouse.
Message 17 of 20
spookyfreakss
In a previous project, we needed to convert files from DWG to DGN format and vice versa. Fortunately, we discovered a tool called Translation Manager, which effortlessly handled the conversion process without any hiccups. We experienced smooth transitions between formats whenever the need arose, without encountering any difficulties. Hope this helps you
Message 18 of 20
dvalentiW5B93
Thank you, I'll have to take a look at that, hopefully tomorrow, no time alotted in today's schedule!
Is this Translation manager within Autocad ? or within MicroStation? Or an add-on ?
Message 19 of 20
spookyfreakss
From what I know, It is a standalone program @dvalentiW5B93
Message 20 of 20
dvalentiW5B93
ok, thanks again.  I googled it and saw there is a company by the name of Axiom that sells this software.
I contacted them with my questions / dilemmas with translating files, so I am anxious to see how much this "solution" might be. Hopefully it will be in the budget, and it will work and resolve my problem!  thanks for the insight .....
