How to check the version of a dwg file?
Message 1 of 18
I want to know if a dwg file a 2000, 2010 or other version. How to check it?
Accepted solutions (3)
Replies (17)
Message 2 of 18
maratovich
Open with Notepad
Find the line "AС ....."
AC1015 = AutoCAD 2000
AC1018 = AutoCAD 2004
AC1021 = AutoCAD 2007
AC1024 = AutoCAD 2010
AC1027 = AutoCAD 2013
AC1032 = AutoCAD 2018
https://knowledge.autodesk.com
https://en.wikipedia.org/wiki/AutoCAD
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 18
Can I check from any pane indicating file property within the program?
Message 4 of 18
maratovich
What ?
Did you see the links in the previous message?
Upon opening a DWG file in AutoCAD, the Command line will show the current format of the DWG file.
www.kdmsoft.net
Message 5 of 18
chriscowgill7373
The only surefire ways is as what has been stated. in the program it will show up on the command line when opening the file, or when looking in notepad, typically the very first line. You used to be able to hover over a file in windows file explorer, but it has said files were created in 2014 since 2014.
Lee Mac also has this program:
http://www.lee-mac.com/drawingversion.html
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 6 of 18
vladimir_michl
The most common way is checking the initial "AC" string inside the DWG file - see http://www.cadforum.cz/cadforum_en/qaID.asp?tip=868
But you can also find more specific information about the originating AutoCAD version - vertical (like Civil, Mechanical...), service pack/build, language - see DwgIntVer:
http://www.cadforum.cz/cadforum_en/how-to-find-which-autocad-version-was-used-to-save-a-DWG-tip10702
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 7 of 18
JTBWorld
Our app DWG Columns is one option.
AutoCAD%202018%20Select%20File
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 8 of 18
BeKirra
1. Open the drawing with AutoCAD then press F2 key to turn on AutoCAD Text Window. Scroll to top. You will see the 1st line describing something similar to this:
"Opening an AutoCAD 2013 format file."
2. Do what maratovich's suggestion in post #2, if you can't open the drawing file with AutoCAD because it is a higher version.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 9 of 18
pendean
Community Legend
Community Legend
Message 10 of 18
paullimapa
Here's a couple of ways:
With drawing opened, type the command ETRANSMIT
Then click on the Files Table tab
Locate the row with the drawing name & expand the Version column
With an empty drawing opened, type the command DWGCONVERT
Drag & drop the drawing into the Files Tree window
Then click the Files Table tab
See attached screen captures for reference.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 11 of 18
Thanks so much Paul!
Both of your methods work.
Message 12 of 18
These solutions show the version of the program that the file was created. For example I specifically save everything in a Autocad 2013 version but it still shows Autocad 2018... Does anyone else have an actual solution to find out with which version a file was saved?
Message 13 of 18
chriscowgill7373
I'm not sure I even understand what you are asking.  All of the posts above give you the version in which the file was saved, that is what the drawing file format is..  There are no markers that say "this drawing was saved from AutoCAD 2021"  you will just see that it is the 2018 file format (or whatever the format was saved down to.)  So you really dont know what version of the program created the file, only what format it was last saved as.
Message 14 of 18
vladimir_michl
DWGintVer gives you a more detailed information, incl. the specific release, build and flavor of the AutoCAD which saved that DWG.
See:
https://www.cadforum.cz/cadforum_en/how-to-find-which-autocad-version-was-used-to-save-a-DWG-tip1070...
https://www.cadstudio.cz/en/apps/dwgintver/
Message 15 of 18
chriscowgill7373
interesting, the way I'm reading it is that it applies the additional data, which is read back from the program.  kind of surprised it works with LT, as it doesnt allow for 3rd party customization.  So this wouldnt work if someone sent you a drawing that did not also have this addon?  Or am I not reading it correctly?
Message 16 of 18
cadffm
If your ACAD can read the file, you can open the file and you can see the dwg version in your log.[F2]
If no version message appears, it is the native version of your program(dwg version 2018 for programms 2018-2021 for example.
Or open the file with text editor to see the format at the first lines (ac1032) for example.
Sebastian
Message 17 of 18
vladimir_michl
No, it is not an add-on for AutoCAD LT. DWGintVer is an add-on for a full AutoCAD and a standalone EXE to batch-check a whole folder. It can detect all kinds of AutoCAD variants as the source for a specific DWG file, incl. AutoCAD LT, Plant 3D, Mechanical, etc.
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 18 of 18
JTBWorld
JTB DWG Columns will show you both the DWG format version and what was used to save it.
Jimmy Bergmark
