@Anonymous wrote:
I want to know if a dwg file a 2000, 2010 or other version. How to check it?
1. Open the drawing with AutoCAD then press F2 key to turn on AutoCAD Text Window. Scroll to top. You will see the 1st line describing something similar to this:
"Opening an AutoCAD 2013 format file."
2. Do what maratovich's suggestion in post #2, if you can't open the drawing file with AutoCAD because it is a higher version.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
