how to check break point along a polyline
I want to circle them up
Vinayv4v
Here is a Lisp From Kent Cooper for circling break points along lines
(defun c:cmark (/ crad ss ln)
(Command "ucs" "World")
(setq
crad (getdist "\nSpecify radius: ")
ss (ssget "X" '((0 . "LINE")))
(repeat (sslength ss)
(setq ln (entget (ssname ss 0)))
(command
"_.circle"
(cdr (assoc 10 ln))
crad
"_.circle"
(cdr (assoc 11 ln))
crad
(ssdel (ssname ss 0) ss)
(Command "ucs" "p")
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/circles-at-line-end-points/td-p/3316...
You need a little bit of modification to try this on polylines.
Cheers,
Vinay Vijayakumaran
Kent1Cooper
If you mean what most people call the vertices of Polylines, this routine places Points at all of them [you can set the PDMODE System Variable to make the Points visible in whatever style you prefer], and could easily be adjusted to draw circles, if you need that specifically.
Kent Cooper, AIA
