How to change command DELETE?
andelozecevic
andelozecevic
Hi
I need help with command DELETE. When I want to delete some object in AutoCad (for example some line) I need to press the button Delete on my keyboard firstly, then select line which I want to delete and press enter or right click on mouse and then press enter again. It takes to much time when you work in AutoCad so I want to change it. I saw that on some other computers command DELETE works in just two steps: select object and press button Delete on the keyboard. It is a much faster way to delete something but I don´t know how to change that on my computer. It would be great if someone could help me.
cadffm
andelozecevic
Ok, thank you I will try that.
