How to align multiple points to snap in 1 point.
- Mute
- Permalink
- Report
I have made some schematic drawings and even with snapping activated I have some lines nearly parallel at small distance between them. When zoomed out they seem to be one line but when zoomed in you can see they are many not aligned on one or both ends.
Is there another way to align them to 1 line than manually moving both ends of all the lines to the one chosen (or added) as reference ?
If I could select all the chosen lines and force all the points of one end to snap into reference point then all the points of the other end to snap into the other reference point then I would be grateful.
I think that its the Nearest Object Snap which is responsible for this unwanted misalignment.
Is there a way to have it activated/deactivated with a keyboard shortcut ?
