how to add the number of sheets
Message 1 of 11
I want to add the number of sheets at the bottom of the template, so i want to add some kind of block that counts the number of sheets or layouts automatically, because I just have many layouts that i just 1, 2, etc as sheets, i don't think that i have sheets in the traditional sense. Is it a way to do that? Instead of manually changing the value of each layout just let autocad do it for me.
Thank you 🙂
Replies (10)
Message 2 of 11
jayhar
Use Field for Drawing Number see the attachments
For sheet numbering field and Auto Lisp also required see the cad file
JAYHAR.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 11
Jayhar,
hi thank you for your help, i found the ctab field but the formula "9 - 1" is not working, so i guess that i have to enter the formula "last ctab" or "ctab - 1" ?
Message 4 of 11
jayhar
Autolisp  to be upload
Message 5 of 11
AutoCAD provides you with the ability to create a sheet layout from one of several existing templates. The sheet layout is based upon a sheet set that you can create using the "Create Sheet Set Wizard."
Plugin AVC_PageNo for AutoCAD and BricsCAD. Numbering of drawing sheets in one dwg file, without sheet set.
Message 6 of 11
jayhar
Upload Auto Lisp, Comment Lfsheet & Select Text It Will Works.
In This Lisp Has Three Comments Lfname, Lfsheet & Lfnumber.
Try It
Jayhar M J
Message 7 of 11
Hi Jayhar,
I see that your way of numbering the sheets works only on your file if I open it with Autocad, but it doesnt work if I open it in AutoCAD LT which is the one im actually using. Do you think is any other way for me to do it in LT? Thank you for you help
Message 8 of 11
jayhar
<<<<<AutoCAD LT which is the one im actually using.>>>>
Auto lisp does not works in LT version
Message 9 of 11
Have you tried using sheet sets, and using a field in an attribute linked to either sheet name or sheet number?
It works well for me- see attached image and look into >sheet sets< and >fields<.
Hope this helps.
Message 10 of 11
timothy_crouse
If you do not want to use sheet sets (which I highly recommend, as it makes project pkg management  simpler) create an attribute for the total sheet count.
ROUGH MANUAL OPTION 🙂
Edit the attribute inside the border block  >>  right click inside the edit row of the attribute editor dialog and slect insert filed.  You can link this to any of the current document properties which you can edit the in or out of autcad  >> still a manual process unless you use something like hurricane script tool
SIMPLER OPTION
Create an Xref called Total Sheet Count  >>  base ref 0,0
have a single piece of text in the file that has the total sheet count that you edit as needed.
Insert it as an Xref in each sheet  >>  use this technique for revision and release date too if applicable.
Sheet set manager is much simpler you get to edit a sheet set property which updates on every sheet.
The only other way to do the auto math version you wish to implement would have to happen through a script.  Again I would suggest Hurricane as it makes script writing simple.  This technique would allow batch processing , smack the go button and go to lunch it is a LARGE project.
Best Regard
-Tim C.
Best Regards
Tim
Message 11 of 11
Jake_CAD
Hi Jayhar,
Is it possible to embed this use of the CTAB variable into a title block?
