How to add SNAP and GRID to bottom ribbon
syanchuck
Message 1 of 27
syanchuck
I need SNAP/GRID buttons on my bottom ribbon, however it was disappeared yesterday.
How can I add it back to the ribbon and why it's disappearing sometimes?
Thank in advance!
Replies (26)
Message 2 of 27
cadffm
Bottom ribbon? Do you mean the Statusbar?
Click on the button at the lower right corner with the 3 horizontal lines (hamburger ;D ).
You can add/remove statusbar items there.
Sebastian
Message 3 of 27
Kent1Cooper
Pick on the three-horizontal-bars "hamburger" icon at far lower right, and a list pops up in which you can check which things you want shown.
Kent Cooper, AIA
Message 4 of 27
syanchuck
I did it multiple time, but the SNAP and GRID are disappeared from here.
Message 5 of 27
pendean
Community Legend
Community Legend
@syanchuck Wondering if a screenshot of your entire fully-maximized program bottom-half showing it from end to end would give us more clues as to your issue.
Go ahead and make sure ABOUT command's pop-up is fully visible in that same screenshot.
Message 6 of 27
cadffm
Snap and Grid doesn't make sense IN PAPERSPACE,
so go to MODEL and check it again.
Sebastian
Message 7 of 27
syanchuck
I do have it on Model Space, however it does make sense for me to have on my Paper Space as well.
Message 8 of 27
syanchuck
It looks like it is fully visible...
Message 9 of 27
pendean
Community Legend
Community Legend
@syanchuck Your screen resolution is too low to show everything: are you running on a 13.3" monitor or at 1024x768 perhaps?
Turn off the buttons you do not need at the bottom instead of having everything on, that should solve your problem with hat display setting.
Curious you did not notice to ask about the masked panels at the top either. Not there yet?
Message 10 of 27
cadffm
>>"I do have it on Model Space"
Then it works well and as designed! It is usual to NOT have it while in paperspace!
>>"however it does make sense for me to have on my Paper Space as well. "
GRID and SNAP are Modelview features only, so it doesn't make sense to have the buttons while in paperspace.
>>", however it was disappeared yesterday."
Sorry to say that, but: They where never there (while in paperspace)
Switch to MODEL tab or jump into a viewport (command MSPACE), where GRID&SNAP is an available feature
and the buttons will appear.
Sebastian
Message 11 of 27
Kent1Cooper
@cadffm wrote:
.... GRID and SNAP are Modelview features only, ....
I can't imagine where you got that idea, but it certainly is not true:
Kent Cooper, AIA
Message 12 of 27
cadffm
Awkward
I just remembered it was removed (in Paperspace) from status bar , however, these were probably just the status bar buttons and not the function.
It was just  a wrong assumption and I couldn't test it at the moment 😧 (for usual I don't use them in layouts for my daily w)
It started with Version2015
Sebastian
Message 13 of 27
Michiel.Valcke
I honestly have no idea how to 'force' the icons in the drawing aids bar while in paperspace, but you can always activate them with the F7 and F9 button. Or type the DSETTINGS command to open the draft settings dialog if you wish to edit them while in paperspace.
Message 14 of 27
dbroad
@cadffm Snap and Grid commands are available in both paper and modelspace and have different settngs for each.  F9 will toggle the respective snap settings for each mode. F7 will toggle the respecitve grid settings for each mode.
@syanchuck I'd never noticed that the snap status indicators disappeared in paper space.  Thanks for noticing.  Looks intentionaly on Autodesk's part though.
I will say that, from past experience, it can be bad to have grid on simultaneously in both paper and model spaces. Snap in paper space can be handy periodically in laying out viewports though, especially to leave room for titles.
Architect, Registered NC, VA, SC, & GA.
Message 15 of 27
syanchuck
I tried it several times, haven't solved anything...
Message 16 of 27
syanchuck
I don't know what is usual, but I have clear client's instruction to work certain sheets on the Paper Space.
I don't know what your opinion based on, but it does make a big sense for me to use the functions on the Paper space.
Message 17 of 27
syanchuck
I have to use F7 and F9 unfortunately instead of the bottom ribbon buttons.
because I have to work sometimes in Snap Off mode, then sometimes in SNAP On, I can't visually see the mode status, only play with the mouse. It is not comfortable for me, sorry...
Message 18 of 27
pendean
Community Legend
Community Legend
@syanchuck You tried what "several times" please?
This is not a full list: are you really running full AutoCAD and without any add-ins or a completely customized menu?
Message 19 of 27
cadffm
It's okay and you can use it (has already been explained), but it doesn't change how the program acts.
Above you can read my current state of knowledge, which no one else has disproved, is described above:
It looks usual for AutoCAD(since2015) not to display the buttons while in paper space.
Use GRID SNAP or [F7] [F9], but the status bar buttons are not displayed in a clean DWG (without corrupt data structure) in your AutoCAD.
[F7][F9] state:  You can add two buttons in the ribbon or you can (only)show the state to the Statusbar as Test!
Samples
Ribbon-Toggle
Macro: '_.GRIDMODE;$M=$(if,$(eq,1,$(getvar,orthomode)),1,0)
same for snapmode..
Statusbar
Command: Modemacro GRID=$(if,$(=,1,$(getvar,GRIDMODE)),ON,OFF)
Sebastian
Message 20 of 27
cadffm
@pendean  wrote: This is not a full list
If you are using 2015 or newer:
Can I see your list in 2015 or newer products while you in paperspace?
Pls share the screenshot of the whole program window incl. the list, thx.
Sebastian
