How to add an item to a rectangular array
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi all
How do you add an item to an already existing rectangular array?
I can't find where it is in arrayedit, if it is there at all.
Mike Kovacik
AutoCAD 2018
Joburg
South Africa
vinodkl
After you have created the array of the object (with associative= Yes) and ended the array command, then you can select the object and click on "Edit source".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
you can add to the source CAD element by Source option . also if you press and hold the Ctrl key, and then select the items in the array you can MOVE or ERASE those items .
Command: ARRAYEDIT
Select array:
Enter an option [Source/REPlace/Base point/Rows/Columns/Levels/RESet/eXit] <eXit>:
Imad Habash
MikeKovacik4928
I am talking about adding in an item that is not part of the array already, ie it is filtered out.
I think I have worked it out. Do a copy with base point and copy the object you want to add to the array first,
before invoking the edit array command, then while in the edit source do a paste to original coordinates,
then close and save, the object is added to the array.
I was hoping there was an easier way, like inventor where, while you are editing the block, you can just click
on the greyed out/filtered out object and it will be added to the existng array.
I must go now, my lunchtime is ended. Will come back again, tonight from home
Mike
