how reassign macro for double clicking mouse wheel or disable it
Message 1 of 15
is there a way to do that?
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
What problem are you actually trying to solve? Your ask is too generic.
Message 3 of 15
dgladfelter
The MBUTTONPAN variable controls the behavior of the "third" button (aka the middle button) within AutoCAD.
The default value for MBUTTONPAN is 1 which tells AutoCAD to support panning when you press-and-hold the middle mouse button or wheel.
The secondary value for MBUTTONPAN pan is 0. When set to that value, the middle mouse button will support the action defined in the customization file.
Looking to the Customization file, launching the CUI command will take you to the Customize User Interface dialog box where you can customize many elements of the AutoCAD interface. Among those is the behavior of mouse buttons.
in the CUI command, the middle mouse button is referred to as Button 3. You can adjust the various behaviors of Button 3 by expanding "Mouse Buttons" within the Customize User Interface dialog box. There you will see settings for Click, Shift+Click, Ctrl+Click, and Ctrl+Shift+Click. Each of those behaviors has a setting for Button 3.
Here's an AKN article that may be of assistance in your endeavors to customize the behavior of the middle mouse button: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Wheel-...
Donnie Gladfelter
Virtual Design Manager, Dewberry
The CAD Geek Blog
Facebook |Twitter |YouTube |LinkedIn
Message 4 of 15
Kent1Cooper
@dgladfelter wrote:
... in the CUI command, the middle mouse button is referred to as Button 3. .... within the Customize User Interface dialog box ... you will see settings for Click, Shift+Click, Ctrl+Click, and Ctrl+Shift+Click. ....
... but unfortunately, not  for double-clicking.  And the AKN article seems to be about getting it to do  what it's supposed to if it isn't, rather than getting it not  to do that.
This question has come up several times before.  I'm not aware of a solution -- in a quick Search, no one had one to offer on [for example] >this thread< or >this one<.
Kent Cooper, AIA
Message 5 of 15
want to use trim instead of extend zoom for example or undo etc
Message 6 of 15
pendean
Community Legend
Community Legend
You want TRIM command to be a mouse button? If yes, does your mouse driver allow you to assign different functions to the extra mouse buttons?
Which mouse and driver are you using?
Message 7 of 15
i have already ordered logitech mouse i will need that also but i know how to change double clicking the wheel
Message 8 of 15
Kent1Cooper
@Anonymous wrote:
... i know how to change double clicking the wheel
Is there a "don't"  or a "need to"  missing there?  [If you know how, presumably there's no need for the thread....]
Kent Cooper, AIA
Message 9 of 15
pendean
Community Legend
Community Legend
One more time... Only your mouse driver can assign different actions to your mouse buttons: find out what those keyboard keys are, then in AUtoCAD you assign those unique keyboard keys to the action you need.
So, for example, your mouse's button #4 can be assigned to ALT+SHIFT+K for example, you then start CUI command inside AutoCAD and assign ALT+SHIFT+K to your TRIM command. Now you can use your mouse button #4 assigned to ALT+SHIFT+K to TRIM inside AutoCAD.
You just have to hope ALT+SHIFT+K is not something you hate to do in all other applications outside of AUtoCAD because that is what you will be stuck with forever.
Message 10 of 15
ВeekeeCZ
I don't think you'll be able to re-assign wheel double click easily. You may need some kind of THIS  solution.
Message 11 of 15
iam sorry i was busy didn't watch my comments i want to know its by wrong. and i can't edit my comment don't know why editing is disbaled
Message 12 of 15
the link you have referred doesn't work
Message 13 of 15
it worked when i used vpn oki but ur talking about logitech iam talking generally about the cad settings
Message 14 of 15
ВeekeeCZ
Just trying to suggest ANY solution. Because otherwise, the answer would be NO. Not without turning off PAN too.
But see yourself... HERE  is quite a comprehensive thread about this.
Message 15 of 15
pendean
Community Legend
Community Legend
One more time:
NO TO WHAT YOU WANT IN AUTOCAD ONLY.
Now go try the other solutions we are all suggesting.
Good luck.
