HOW ICAD MAKE ATTRIBUTE WHICH AUTOMATICALLY UPDATED ON SAVING FILE.
DEAR ALL
HOW I CAN MAKE ATTRIBUTE THAT WILL AUTOMATICALLY UPDATE ON SAVING THE FILE.
I AM ATTACHING HIGHLITED RED  COLOUR  EXAMPE.
THANKS
LAST SAVED BY OBAID.PANDT ON 27/09/2018 10:56 AM PLOTTED BY OBAID UR RAHEMAN ZAFAR ON 2/26/2018 11:23 AM
cadffm
command FIELD
http://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-742C92C3-1284-4722-B650-C46F9191C701
But "plotted by", that information isn't stored in DWG, so it is impossible to display this Information
AND all other ones always correct.
ONLY this information would be possible with fieldeval setting to 4, but you need another value for the other ones.
Field example in MText:
180927-2.JPGIf you really need a "attribut" i would use a constant attributdefinition,
but it is also possible as attributvalue (non-constant).
Sebastian
check attached cad drawing
IN THIS DRAWING SAME PROCESS USED INT THE BOTTOM OF DRAWING.
