How I can print high quality images as a PDF file in AutoCAD?
a.am1
a.am1
Hello
Because when I insert the image (Raster data) to AutoCAD then print it as a PDF file I loss the quality of the image.
S.Faris
Sorry to say this, But Autocad cannot increase the quality of an inserted Raster image.
SALMANUL FARIS
Alfred.NESWADBA
Some questions:
  • which resolution does the image have?
  • which resolution do you have set for PDF file creation
  • what size does the image have on the PDF (measured in paper units)
As alternative ... use command _ETRANSMIT to create a ZIP file from your DWG/PC3/Image and upload that ZIP-file so we can test it on our systems and see all these details.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
