How do you swap/ replace title blocks in standard AutoCAD?
Message 1 of 12
I have a set of drawings I created with a template title block. But my CAD manager has updated a new template (different file). How do I swap my existing title blocks with the new one?
The new one works if I create a new drawing but I just want to replace the title blocks in my existing drawings.
Replies (11)
Message 2 of 12
vinodkl
Hi @Anonymous
You can copy the title block from the new template and paste it into the drawing which you are working on if you have a single layout in your drawing, if in case you have multiple layouts in your drawing then you can copy all the content from the modelspace using command ctrl+c and then paste (paste to origin command "PASTEORIGIN") it into a new drawing created using the updated template.
While copying the title block from the new template make sure the block name of both title blocks is not the same. If its same then while pasting the new title block it will be replaced with the old title block. If that's the problem, you first need to rename the old title block sing the command "RENAME" and then paste the new title block 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 12
Kent1Cooper
Is the title block a Block in the existing drawings?  If so, and if the insertion base point of the new one [set with the BASE command in the "different file"] is the same as the Block's insertion point in the current drawing, do this at the Command line in each existing drawing:
-INSERT
CurrentBlockName=DifferentFileName
Note the hyphen preceding the command name, to get the Command-line version, rather than the dialog box.  The two names must surround the equal sign with no spaces.  If the new one is not in a location where AutoCAD knows to look [some place in the Support File Search Path list, in the Files tab in the OPTIONS dialog box], you will need to include the path with the file name:
CurrentBlockName=X:\Your\File\Path\DifferentFileName
You can omit the .dwg filetype ending -- it won't consider any other kind of file.
It will ask whether you want to redefine the Block -- answer Yes.  Then the Block will have been redefined, and you can cancel the Insert command without completing insertion of another one.  All existing insertions of it will be updated, retaining their Layers, insertion points, scale factors & rotation angles, including in all Layouts if there are more than one.
The name of the Block in the current drawing will still be the same as it was, so if you want it to change to match the name of the new one's source file, use RENAME.
In the future, use XREF's for title blocks, instead of Blocks.  When you change the source Xref'd drawing, it will automatically be updated every time you open any drawing it's Xref'd into, without your needing to do anything.
Kent Cooper, AIA
Message 4 of 12
3wood
You can also press Ctrl+2 to use Design Center to insert the new title block and replace the existing.
Message 5 of 12
JTBWorld
If you have many drawings you can use our app JTB Batch Change
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 6 of 12
johnUAVLJ
Community Visitor
Community Visitor
Great help @Anonymous -- Thanks.
I just want to add:
Try the command “ATTSYNC” to update the attributes locations
Message 7 of 12
rchacinRUGAK
Hi, Kent,
I'm ACADE user needing to do what's described in the original post. Your answer is the closest I've managed to get so far, but I still have some issues.
For background, I am working on a set of drawings that were drafted in a different software and then exported as .dwg, which I then imported into a project. The "title block", just as every other "component" in the drawing is just a block without any kind of intelligence. I would like to be able to replace what's in it with an actual title block whose fields can be updated globally from a Title Block Update... I have a title block that matches the needs of the project, and using it would make the automatic page count and relocation much easier than manually typing on each block/page.
You method got me to be able to replace the existing block with my [title] block. However, it's still just a block albeit with attributes (if accessed through the Block Editor).
I know this is an old post, but I wonder if you have any further advise that would help?
Thank you!
Message 8 of 12
cadffm
Not sure what your issue is,
nested blockreference or just attributes?
Does it work with a new blockreferenc? Run INSERT
If so:
Don't forget to update your existing blockreference (Attributes).
As mentioned above, run Attsync
to update your blockreferenc.
Sebastian
Message 9 of 12
JTBWorld
What is it you next want to achieve next? Do you have regular text from the old block that you want to be added as attributes? If so, you need to get help to create a script for this conversion. Feel free to contact me if needed.
Jimmy Bergmark
Message 10 of 12
rchacinRUGAK
Hi, Sebastian,
I am not sure I follow your train of thought, but to help visualize my predicament:
  • Running "-INSERT" did allow me to paste a custom-made .dwt title block on an existing drawing.
  • This .dwt template/title block works perfectly if used in a new drawing, but when inserted through the method described above it can no longer be updated via traditional means — that is, Title Block Update button.
  • If I don't a "ATTSYNC" it retains some of its attributes, so I can double-click it and fill them out like you would any other component. But they are out of place.
  • If I run a "ATTSYNC" then those attributes disappear. By double-clicking the title block then I am prompted with the Block Editor. From within  the Block Editor I am then able to to see the attributes. However, this is ineffective for me.
What I would like to accomplish is to simply be able to use the title block template in the same way I would in a new drawing. That is, update the data in it such as Project Name, Drawn By, Description #1, so on and so forth by simply doing a Title Block Update.
In order to edit this information in the current drawings I have to double-click the pseudo title block, go in the Block Editor, and then edit each text field one by one, on every single page. Where there's potentially dozens of them, it turns into a very poor workflow.
PS #1: I can't run "INSERT" (without the dash) because that wouldn't allow me to insert the .dwt template, only a .dwg drawing. And what I am trying to do is not change the visuals/aesthetics of it — I am trying to bring intelligence to it.
PS#2: These drawings came from a different software (EPLAN, I believe), so nothing in them has any intelligence, including the title block. In other works, the title block in these drawings is just a block with a drawing framing the page, with text fields to account for the regular stuff you'd expect to find in an electrical schematic.
Message 11 of 12
rchacinRUGAK
Hi, Jimmy,
I sort of laid out the problem I am facing on my reply to Sebastian in this thread. Here
Message 12 of 12
cadffm
"PS #1: I can't run "INSERT" (without the dash) because that wouldn't allow me to insert the .dwt template,"
And do you know why? Because  .dwt files a not to use as drawing or blockdefinition files.
They are for file templates only!
#2 -
This old insert has Attributes!
The old block has no attributdefinitions.
You will loose values because you don't use the same attribute names, thats the problem!.
Hey, without your drawing "original" and "mynewblock" it's just guessing. But i have a lot expierence 😉
I think your insert has attributes, flaged as 'constant', what is "impossible" to do by GUI in Adesk-Products, but it is possible by other programs and by programming too.
It's also possible to edit the attributes to be editable again.
And it is also possible to redefine the blockdefinition aswell.
So you have editable attributes abd the blockdefinition is build to create the same inserts, with the same editable attributes.
But not ootb, you need a tool to do this.
(I don't know about a all-in-one Tool on market, but i know that it works, vecause of my own function fir FixEplanExports)
Sebastian
