How do you set N)orth/Top as the Top view?
ktnalive
ktnalive
I am new to AutoCAD 3D and began drawing some walls for an imaginary building to see what I could do as I began finishing I noticed the top view/home view was the right view. I have tried fixing the orientation but to no avail. How do I fix this issue so that my top view is my TOP view?
The picture shows the "right view" as the top view, which is displayed as the back view, etc. In essence, I need to be able to hit the home icon and see the top of the building and not the left side.
paullimapa
You'll have to rotate & enter all to select the entire model so that the right view is now rotated to become your top view.
Paul Li
IT Specialist
@The Office
vinodkl
Hello @ktnalive
Please type in the command "VIEW", select "TOP", "set current" and click "ok". I hope this helps 🙂
Please take a look at the image for reference.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Tomislav.Golubovic
Reset your UCS, type in UCS in the command line and press enter twice
ktnalive
Thanks, I got the TOP view back to north. Now I will just need to do a 3D Rotation.
