AutoCAD Forum
How do I turn a 2D drawing into 3D sketch drawing?
6 REPLIES 6
585 Views, 6 Replies
Hi, I am wondering if anybody can help.
I have created a 2D drawing of the front of a piece of furniture I have designed. I need to create it into a 3D drawing like shown below. Is this something which can be done on AutoCAD? (left image my design, right image how I need it to look)
Thank you
My 2D drawing (image 1)My 2D drawing (image 1)3D sketch (image 2)3D sketch (image 2)
Thank you
Labels (3)
6 REPLIES 6
Patchy
Patchy
Surely, use command EXTRUDE
If you want them to be 3dsolid, use command boundary on the lines first.
in reply to: Patchy
I have tried this but when I try and 3D rotate my drawing it won't let me get the angle like my second image.
in reply to: Patchy
I am also trying to recreate this in the 3D workspace however, when I try to draw a line in between 2 lines I have already drew so they all connect it won't let me. For example, the two vertical lines highlighted I need to draw a line across between the two lines however it won't connect if that makes sense.
in reply to: Patchy
I also won't let me extend up the line when you hover over before clicking to create a line. Do you know anything about this too?
Sorry I am new to AutoCAD!!
Thankyou 🙂
Thankyou 🙂
skintsubby
skintsubby
Hi @Anonymous
Have a look at the UCS and manipulating the UCS. It's what allows you to draw in different planes
Mark
Hi @Anonymous
Mark
Tags (1)
Patchy
Patchy
Attach your .dwg, let's find an easy way to show you.
AutoCAD Inside the Factory
